One low beam headlamp not working
jimtellier
New Hampshire
Hi all,
Seems like it should be a simple issue right...drivers side low beam went out because I accidentally arced the connector during replacement. Pretty dumb of me but now I'm really having an issue trying to find out what I burnt out. There are not individual fuses or relays as labeled anywhere in the cab (lower left side panel) or in the engine bay (by the window/drivers side). I thought it might be a simple "disconnect the battery" issue but nope. I know it's not the bulb itself and one of the "google" thoughts was maybe a B+ in the engine fuse/relay box. Everything passes muster. I even took a light probe on ALL the fuses...nope.
Any thoughts? Could there be a reset through the instrument panel display?
Thanks in advance.
